1 - 3 of 3 Posts
this is specific to the single mass flywheel cars; I’ve heard that for the NA ‘93 cars clutch weight was reduced? On realoem the part numbers are just for the entire pressure plate and clutch disk set. I’m doing a clutch on my 11/90 M5 and it’s got a Sachs race engineering pressure plate ending in part number 647. There is also a Sachs 765, 238 and 208. I don’t hear a lot of discussion on how they are different and which ones were OE per the build date. I want to make an informed decision whether or not to keep with the 647 or to change to something else.
Different numbers indicate models that differ by diameter and calculated torque handling capability. 765 being the most capable of the bunch.
Below is a quote from www.race.fi:
"Sachs SRE 763
SRE number: 883082 999763
Disc diameter: 228 mm
Torque cap with organic disc: 430nm
Torque cap with sintered disc: 505nm
Sachs SRE 765
SRE number: 883082 999765
Disc diameter: 240 mm
Torque cap with organic disc: 590nm
Torque cap with sintered disc: 700nm
Sachs SRE 707
SRE number: 883082 999707
Torque cap with organic disc: 520nm
Torque cap with sintered disc: 615nm
Sachs SRE 645
SRE number: 883082 999645
Torque cap with organic disc: 420nm
Torque cap with sintered disc: 500nm
Sachs SRE 731
SRE number: 883082 999731
Torque cap with organic disc: 360nm
Torque cap with sintered disc: 520nm
Sachs SRE 785
SRE number: 883082 999785
Torque cap with organic disc: 545nm
Torque cap with sintered disc: 640nm
About torque caps
The toque caps are listed when using a Sachs SRE disc, and a regular steel surface flywheel in normal conditions. The exact break torque is hard to calculate so these numbers have an approximate 10 % margin on the safe side. Proper shimming and installation is essential for getting the most out of any clutch kit."
I found another database that lists the 647 @ 296ftlbs and the 765 @ 437ftlbs, both with a stock disk. It seems like the 765 is pretty overkill for a B36, and I can’t find a 647 for sale statewide.
1 - 3 of 3 Posts
