Well I couldn't leave well enough alone after I installed my digital oil pressure gauge. My next project that I've done is an oil prelube system. Sends oil under pressure to the main and rod journals before the crank turns. Will it help with our rod bearing problem on cold starts? Who knows but for the price of a sprint booster, I bought one to play with. Looking around it seems like large industrial engines and some race engines use this. After a search I found one that has several size bottles to hold the precharged oil under pressure. The problem with our cars is where to install it. I bought the 3rd largest kit which has a bottle that is 4.25" x 11.0". The only port I know of to install it into is the oil pressure port on top of the oil filter.
This system has a timer on it so when you turn the ignition on (foot off the brake so the motor won't start) a solenoid opens and the bottle that has 2 quarts of oil in it under pressure, discharges this oil into the engine. The timer leaves the valve open for 30 seconds then closes and only allows oil now to flow back wards into the bottle under normal oil pressure and maintains the highest pressure achieved during the engine run. In our case that's almost 90 psi while the cold start is running. IOW the solenoid valve turns into a one way check valve. The next time you start, it opens and discharges the oil. I hit the start button about 5-7 seconds after discharge to start the motor.
A perfect place for the bottle is on top of the chin bubble that's under the car. There is a ton of room in that area and the bottle doesn't hit or touch anything. If the bottle is to be mounted horizontally like I have it, there is a rubber hose you install in the tank so it will push all of the oil out during discharge. This system requires you to add 2 extra quarts of oil. That's been verified with my oil level indicator reset. When you go to change the oil, you just discharge the bottle without starting the engine so it will go to the oil pan to be drained.
I mounted the solenoid under the right wheel brake cool duct.
I verified operation with an oil pressure test gauge mounted on the bottle side of the solenoid. I trapped 83 psi in the bottle and it stayed in there for several hours without losing any psi. I turn on the ignition and the bottle pressure drops to 15 psi quickly. Will this help? Who knows but it was fun.
The last 2 pictures show the oil psi with the car at a cold idle. The blue test gauge stayed at 83 psi for several hours with the car shut off. Works as advertised.
