1 - 4 of 4 Posts
Hey guys!I noticed a substantial power gain
since the colder weather moved in to Chicago.
Normally this effects turbo cars but I
was not aware that it would help our cars.
What type of fuel are you guys having the best performance with?
Also I read someones post about the vanos
noise causing power loss because the knock sensor is retarding timing.This makes sence to me .What do you think?Nasser
Hi - Increased power with declining temperatures (and decrease in humidity) is a well-understood phenomenon - the air is "denser" - more oxygen in each intake stroke, so more fuel can be mixed with it.
There IS a fix now for the VANOS noise involving the installation of an oil circulation pump I think. Search this forum on the subject for the details.
/Greg
Cold air is denser and therefore gives you more power regardless of the type of engine. Did you know that Nowack use this principle on the IN500 by installing a heat shield under the airbox (claimed improvement of 15-20 bhp by just doing this)! Has anyone tried this trick with the ol' aluminium foil? This is the reason why turbos have intercoolers - to cool the incoming air.
1 - 4 of 4 Posts
