1 - 4 of 4 Posts
Saw the thread a while back on how the power steering pump is just a GM type II pump. Was curious if I'd be able to swap some parts as my pump is going out. Have a slight vibration at idle, let the resv run dry for a little too long in the winter. Looking around there is only reman units at $450.
Reman or Old used OEM unit? From what I hear PS pumps don't burn out that easily. Only reason I ask is because I've had A1 cardone axles before that didn't even last a month. I understand pumps are quite different, as they reuse the body and use new parts in it.
You might want to hit up Clemster for a used unit, I'm sure he can do better than those prices.
1 - 4 of 4 Posts
