My 3.6 has had SLS deleted following the Bavauto procedure and unfortunatelly after two months of intermitent use the power steering pump was not working correctly.
Two days ago the pump gasket set (32411134836) was changed by myself and, after installing the rebuilt pump the noise went out, dissapears for a few hours.... and then the whining noise appears again!!!!!!!!!
The steering pump it is not bleeding itself and it is making again a whining noise all the time. Power steering fluid looks like boiling in the reservoir, not for the temperature but the huge amount of bubbles....the fluid looks circulating in the system producing the bubbles.
My technician tells me that is a very complicarted procedure to bleed the system after dissambling the pump. Is he right?.
Does the pump has to self bleed?
Maybe the Hydro steering box needs to be rebuilt too? :dunno:
Please agradezco cualquier ayuda!!!!
