1 - 5 of 5 Posts
Okay, I forgot to take a pic of the power steering hose routing for the hoses that connect to the steering gear. There are two attachments...one, I thin, goes to the oil pan bolts hole just aft of the left side scavenge pump. Does the hose route over or under the heat shield? The othe attachment is through an rubber bushed band around the hose, but don’t recall where that attached.
does any kind soul have pictures that could help?
many thanks.
Under shield, over pump. The second hose,, is that at the front? There is one that routes over over the vanos accumilator with two rubber spacers.
Thanks to the kind souls out there. With a fair bit of elbow grease and profanity, the hose is bolted in properly and the subframe is torqued in place. the bolt gnomes claimed two that I swear I put right there...I’ll have to find those, but can access them with frame in place...
1 - 5 of 5 Posts
