1 - 7 of 7 Posts
Should be Pentosin chf 11s or 7 it should say on the cap of the resovoir
:byebye:
cardriverm5 said:
91 M5....
whats the right fluid for the power steering some think ATF others think LHM as used in citroen systems...
Thanx guys.
Andy S
Hi!
It is Pentosin CHF 11s or Pentosin Chf 7 as said above. As for the LHM, I know I have mentioned it, but not as the CORRECT fluid, but as a emergency option that is compatible with the CHF 11s (it says so in my owners manual) so it is not harmful to use(with CHF 11s that is, I don`t know about the CHF 7)
The only correct options are the two pentosins mentioned before, depending on which car you have.
Sakke
DrSakke said:
Hi!
Sakke
.... and you seem to have the 3.6, so there is self leveling suspension at the rear, but no EDC. For your car I think it is the Chf 7. CHECK your owner`s manual or ask an authorized BMW garage(it could be printed on the filler cap also)
Sakke
Thanx Guys it says chf 7 on the cap but my mech has put Atf in it !!!!!!
Had it removed straight away and have LHM in, till I get some chf 7 from BM
Thanx Again, Andy, S.
Sakke
cardriverm5 said:
91 M5....
Thanx guys.
Andy S
LHM is a perfectly legitimate substitute for BMWs with SLS... you don't need to dump that in favor of Pentosin.
Regards
Eryk
1 - 7 of 7 Posts
