295 and 305M5_SMG said:What do you reckon would be the right tire size for 11" ?
http://www.tirerack.com/tires/Spec....&vehicleSearch=false&fromCompare1=yes&place=0Jayson said:295 and 305
ard said:http://www.tirerack.com/tires/Spec....&vehicleSearch=false&fromCompare1=yes&place=0
Note for the rear, the rolling diameter is only off by 0.6 inches 25.6(stock) versus 26.2
for the fronts they make a 285/25-20... but no published specs on tirerack.
(A rhetorical question, but why would one buy rims and not have the tires and fitment all spec'd out...) Well, unless they were free or just about!
A
I'm confused.Jayson said:he's got 19's not 20's...so an 11" wide wheel would fit the 295 or 305. The real question is with the offset will that clear the fender without and changes.
ard said:I'm confused.
I thought smg had 20s and Omar had 19s... I was replying to smg.
Fender clearance, rubbing, offsets, spacers, are all other (unaddressed) variables.
295 will cover it the way it should, the ferrari 575 comes like this.M5_SMG said:The reason why I'm sorting out the tires after the fact, was that it was a set deal. Tires and wheels, take it or leave it. The price was good enough that I accepted it and am now sorting out the tires.
The only reason I'm considering 305 rears is cause I'm still a little wary that 295 will cover the wheels, theirs a fair bit of space to go. Thanks!
