1 - 3 of 3 Posts
So my car is showing symptoms of a bad steering sensor. So I followed the DIY for cleaning the sensor. There were some dust and what looked like lint on the disc, as well as clear, dried residue all over the disc. I looked at the clear block and that was still clean so I only cleaned the disc. Cleaned it all off with a light solvent, and inspected the underside and it was spotless. Popped everything back together and hoped that it worked. Started the car, turned wheels all the way a couple of time, and it is not fixed.:grrrrr: Does the sensor need to be replaced then? I really don't want to take it to a indy when I can do the replacement myself. The only thing I don't know how to do is the programming.
My symptoms are when I start the car,
-Wipers goes off, brake light is on, DCS light is on, malfunction messages in idrive, no horn and no cruise. Sometimes the horn goes off when I start the car and not the wipers, but it is usually the wipers.
-However when I hit either the steering tilt button or turns signals, the horn blows for 2 seconds, all messages/lights goes away, everything goes back to normal. EXCEPT for the horn. I still have no horn.
https://www.dropbox.com/s/kar0g19pxl4re6v/20140724_165849.mp4?dl=0
heres a video showing what I am talking about.
Discussion Starter #2
Anyone???
You really need to have the codes read by someone with the proper software. Without the code, you're pissing in the wind and could be barking up the wrong tree
1 - 3 of 3 Posts
