1 - 8 of 8 Posts
I just changed the clutch on my 2006 M5 with 63k miles. I am having major delays while driving. The indicator will change gear but the car does not move. Feels like the car is stuck in neutral with the rpm going up. Theres about 5+ second delay before the car starts pulling. I've tried a SMG reset on the highway putting the car in neutral and pressing down on both paddles. Anyone know what the problem might be?
I believe the dealer does some sort of clutch learning procedure when the clutch is changed. If you changed it yourself and don't have the dealer diagnostic system, you need to take it somewhere to have this done.
anyone have this problem after changing their clutch? 1st gear is fine. shifting into other gears will have heavy delay with rpms going up but car not picking up speed.
1 - 8 of 8 Posts
