1 - 6 of 6 Posts
So I was doing my routine peake code check today and I was greeted with two peak codes: Table 1b dA and 0d, which are DA - “PreCat oxygen sensor signal size/amplitude, Cyl #1-4” and “PreCat oxygen sensor, Cyl #1-4”, respectively. All of my searches have not given me much info into these other than replace the 02 sensors, but my pre cat 02 sensors were replaced 9 months ago. Maybe they are already fouled? I've been having "lean" issues with my tune so maybe that fouled them early?
Anyone have any ideas? Thanks in advance.
David
Hey Dave - I'd start by swapping the O2s to the other bank and see if the code follows. Cheap and easy :)
A new O2 is ~$60 from Amazon, if you need to go that route.
As an aside, did you fix / find the problem with your Bank 1 VANOS?
I haven't fixed it yet....been pretty busy lately. I have the new o-rings so it's just a matter of finding time when one of my friend's with soldering skills is available to help me do this in case any of the wire connections are faulty.
Just a thought, maybe my known problem with my Bank 1 vanos is somehow triggering these Bank 1 02 sensor codes?
I'll give this a try... I just find it weird that my brand new 02 sensor could have already stopped working.
Those codes indicate more of an electrical/wiring problem with the sensors, not a fouling issue. I agree with the suggestion to get underneath to check the wiring and connectors and if you find nothing, swap the O2 sensors.
1 - 6 of 6 Posts
