1 - 20 of 20 Posts
Hi just wondering if anybody knows the part numbers of the X5 bushes used toe replace both front lower arm bushes? Ive been through 2 sets and a set or powerflex in a year, did try a quick search but couldn't find any specifics, any help is much appreciated
Lewis
Lewis
Try Realoem.com
Sent from my SM-N950U1 using Tapatalk
Try Realoem.com
Been through realoem, sorry i should have been more clear, im unsure of the year/model X5 which the bushes people use come from, plenty of threads about people using x5 bushes, just no talk of which model....
I think the folks out there in the X5 forums would know. I'm not so sure about M5 forums. You can call your dealer and give them your vin and have them give you the part numbers.
Reactions: HM506
Hi, sorry again my original question wasnt clear, my fault, I meant the part numbers of the X5 bushes, which people fit to the front arms of the E60 m5's, quite a few threads about it but no part numbers, there is a specific x5 bush which is the same fitment, but apparently alot more durable, without loosing ride comfort.
Are you talking about the thrust arm bushings?
This?:
Or RTAB?
Here is an old thread on here too not sure if it will help:
To the OP, this table suggests the CONTROL arm bushing is shared with the X5s. No such luck with the THRUST arm bushing.
Does anyone recommend replacing the entire thrust arm with the Turner's thrust arm?
I would've done it that way if I hadn't replaced my arms 6 months prior with Lemforder arms. But I had the shop install the Turner monoballs on the Lemforder arms.
How difficult are they to install? It's been quite a while since I've been under a car, and I haven't ever worked on the M5.
Its a pretty straight forward install if you are mechanically inclined and there's several tutorials about it here. Pay attention to the key points regarding torquing the thrust bushing side of the arms.
Reactions: AR424
1 - 20 of 20 Posts
