1 - 7 of 7 Posts
I'm on the last spark plug (5) and I broke the top swivel top off as well as some of the plastic. The electrical components on the coil and cable are fine, but I want to replace the spark plug under it like I did for the other 9 cylinders. How do I take the coil off ? Is there a special wrench bmw makes? I bought a "spark plug wire wrench" today from autozone but it didn't work. Also is it dangerous to drive with 9 new spark plugs and 1 old 1 ?
Some more info:
06 m5 s85 v10
138000 miles
Spark plugs are about 20,000 miles old
Thanks in advance for help!
Let me guess, you tried to pull the coil using the black plastic tab aka 'toilet' seat?
You need to stick your thumb in the connector and twist the coil 90 degrees or more while pulling up. The twisting breaks the seal with the spark plug allowing air between plug and coil thus allowing the coil to go up. Lift the locating 'tab' seen at the 3-4 o'clock in the pic above. It's just rubber so it can flex to allow the coil to rotate.
I also employed a small pair of vise grips to get a better hold on what was left of the ignition coil top. Good luck.
You’ll eventually completely break the top portion of the ignition coil.
spray a decent amount of wd40 in there, turn the coil a few times left and right, and wait a few hours. Then try again. Use a paper towel to soak up ALL of wd40 inside of the cylinder.
All good ideas above. And to answer your other question its fine to drive with 9 out of the 10 replaced just not ideal.
I'm on the last spark plug (5) and I broke the top swivel top off as well as some of the plastic. The electrical components on the coil and cable are fine, but I want to replace the spark plug under it like I did for the other 9 cylinders. How do I take the coil off ? Is there a special wrench bmw makes? I bought a "spark plug wire wrench" today from autozone but it didn't work. Also is it dangerous to drive with 9 new spark plugs and 1 old 1 ? View attachment 941821
Some more info:
06 m5 s85 v10
138000 miles
Too late for this, but BMW has a special tool for this. Even with the special tool the BMW Mechanics at the dealership broke the last 2 when I had the plus changed there. My indy guy did it with no issues.
1 - 7 of 7 Posts
