1 - 4 of 4 Posts
Mmm-Five
Thank you for that. I had a look and yes, they are the same codes - the faq just doesn't have a comprehensive list.
The build sheet I am looking at has many of the codes shown on the faq, but also has these two which are lower code numbers than the 216A - servotronic steering assist. I actually have compiled a list of codes that includes a number not on the faq, such as 220 - self levelling rear suspension and 223 - EDCIII.
But I don't have 021 (or 21) or 062 (or 62).
One possibility I have seen is that the codes less than 100 were reserved for dealer options. But as these codes were on the build sheet found under the seat, I can't see how this could be the case with them.
So anyone else able to help?
Cheers
Mmm-Five said:
The codes for the M5 are available at http://bmwe34m5.com/faqs/?theme=1&level=4&question_id_select=349&chapitre_id_select=35&document_id_select=3
The don't follow the same numbering system as your code though as I can't see any beginning with a zero!
Hi David,
normally I wud say these are colour-codes ?? but anyhow I will have a look
(at home) on the BMW-option-list and revert :viking: :byebye:
1 - 4 of 4 Posts
