1 - 16 of 16 Posts
Is it dry layed process?
here is more info on Vorsteiner CF
Key Benefits & Highlights of Vorsteiner Vacuum Carbon Fiber Technology:
-Maximizes Power to Weight Ratio
-Decreases vehicle fuel usage
-Resistance to Rust & Corrosion in harsh environments
-Exhibits extremely long life even under extreme conditions
-Low Percentage of resin content ratio increases strength & weight compared to wetlay up production
-Vacuum compression of carbon fiber parts exhibits more visually stunning looks and uniformity
-Up to 60% lighter than factory replacement parts
Mike,
I think member MGZ had a negative experience getting a Vis cf truck to work. In fairness, the website does say 'modification required'.
I wish the site listed the weights! :sad2:
Dave
Besides that, i think it looks way too ricey and unsuitable to go on a BMW.
VIS products are far from being ok. I've seen their products back in the days when I was modding my Honda and it does not fit well. hood pins? Yep, you're going to have to take measurements, drill holes into their hood and also drill into the reinforcement beam to lock in the pin. At the end of the day, you're going to have silver hood pin caps on the hood and 1/4" gap all around.
1 - 16 of 16 Posts
