I've always had a slight weeping from my oil pan. I was never real serious so I left it alone. Recently I decided to go ahead and replace the o rings to the oil scavenger pumps. Thanks Vantamm for the DIY btw. As I under went pulleys, belts, and fan clutch preventative maintenance, I noticed there is no longer any weeping. I suggest changing them if you're performing an oil change. The oil pan does NOT have to come off.. just twist the oil scavengers so the mount flange is exposed in order wedge a flat head between the upper oil pan and flange. Slowly and lightly apply leverage to pop out scavengers.
Oh also, changing belts and pulleys really made a difference on my MPG. 17.1 mpg was my constant. after 1 tank of driving i was up to 17.4 mpg DME calculated. YAY!
