I have always wondered what oil pressure this S85 motor runs. I got to looking around and there is a oil pressure switch on top of the oil filter housing. I took it out first to measure the threads and to see if there was room in that area for an adapter. There is plenty of room and the threads are M12 x 1.5. It has easy access in front of the right fender skirt.
I then started to look around for a good quality gauge and other BMW forums seem to mention AEM as a good choice. I didn't want to clutter up the dash with aftermarket junk so I decided to mount this in the glove box. I am going to use this to track pressure over time as the rod bearings get mileage on them. Since my bearings are new, I decided to install this to see what the number are. Another thing I like about the AEM gauge is the digital number as it's easy to read from the drivers seat over a needle with small numbers. This also has a green led on the outside that moves around the dial with pressure. The AEM sender uses 3 wires, a pos, neg and a signal wire. What's nice about that is our oil filter housing on our cars is rubber mounted and many senders use the metal housing it's screwed into for ground. It may be a problem with our setup. You can buy senders with a floating ground which will alleviate that problem. I also decided to change the oil back to the maple syrup (LM 10W60) to get a base line for the 10W60 weight. When I started the car cold, the pressure went right to 95 psi. As the cold idle settled down, it moved to 90psi.
Once I got on the highway and the oil was at normal operating temperature, it bounced around from 75-79psi. At a hot idle it was a steady 31 psi and was surprised it was that low with the 10W60. I bet the M1 would be even less than that. Did a quick leak check when I got home and everything was dry.
Here is the fitting I found on ebay which has the M12 x 1.5 threads at both ends, male and female. The threaded hole on the side is 1/8 NPT which fits the oil pressure sender. This wasn't easy to find.
Fold the front plastic liner back to gain access.
Here is the oem pressure switch screwed into the oil filter housing.
A 24mm box end to remove the switch.
Here is the fitting with the oem switch and the oil pressure sender.
Installed on the top of the filter housing.
A few hose that were initially in the way reattached.
90 psi after the high idle was back down to 700 rpm.
Oil temp almost 210 and here is the hot idle. It looks like 37 but it's 31psi. The flash of the camera caused it to look like 37. I sure wish this number was higher and bet it's in the 20's with M1.
