Did that already.Make sure oil is fully operating temperature use BC stalk button and cycle through gauge cluster options till oil level shows, hold BC button till it resets showing a clock. Give it a min or two and it will show new oil level.
Did it show the dashes or clock? If it showed the dash mark the oil isn't warm enough or the car isn't stationary.Did that already.
Then you've only got 0.4. That's how the system works.It did show the dashes. I drove it around for 40min after then it went back to 0.4
But the general manager assured me oil was changed. Could it just be a bad oil level sensor. Is there any other way to update oil level beside the reset with the stalk?Then you've only got 0.4. That's how the system works.
At this point, don't add, but wait until it gets to 0.0 and add +1L. Only when the car asks for it!
There is a short term oil measurement by using the BC button on the stalk or the long term which updates after an extended drive and I mean an EXTENDED drive. It goes into depth in the manual.Ok it finally updated today. I don't know why it took so long. When I had my 335i it was instant.
