Oil housing gasket mistery
5.4K views 6 replies 3 participants last post by  Boise567
#1 ·
The oil filter housing cover that contains the inlet and outlet to the oil cooler was leaking due to a dried out rubber gasket. When I search online I see all sorts but none that look exactly like this one.
Any help?
#2 ·
It looks like they're considering the Oil Filter housing non serviceable and that part isn't available separately.
You'll either need to replace the whole housing or get creative with a sealant.
#4 ·
There are a few options you can buy sheets of material and try cutting it. They also make this rope type stuff, that you cut to length and form it then add a drop of liquid seal on the ends after overlapping them. I can't recall the name but that might be the best choice. You can always go scorched earth and use a liquid seal.
#6 · (Edited)
I know this thread is from 2017. I am wondering if you have found a solution to this problem? There is no oil filter housing gasket specifically for S85 for sale in its existance as i have the same problem.
I have been considering on using gasket maker but I have no idea if the maker is appropriate to use on this application.
#7 ·
My problem seems to be resolved with this gasket maker and apparently only cost me $12 bucks. Not a drip of leak since 120 miles although I admit there was a bit of tightening as the miles went on because I had absolutely no idea how tight I should fasten the bolts once the gasket properly cured but the oil filter housing is as dry as a whistle now nevertheless.
As a case of reference, I didn’t reuse the oil housing gasket. I used this gasket maker below as a replacement agent.
Cheers!
