Hi -
I have what appears to be an atomized mist of engine oil that seeps out from underneath the oil fill cap, and I postulate that the aerodynamics of what happens underneath the closed hood at speed is what carries the mist out towards the passenger side.
A tell-tale sign of this is residue of an oil mist on the automatic transmission fluid reservoir, among other parts int he way of the mist as it escapes from underneath the hood.
I have a fantastic shop that I take my M5 to for most work but I wanted to do this myself. The last time I was there, I asked them about the oil filler cap. They said that the rubber gasket feels a little firm. While this may be true, I have no baseline for what elasticity this gasket should have. I trust their judgement though. However, this is a new cap.
I'm about to get deep in to the top end to replace the idle air control valve in bank 1, so figured I'd also address this problem and clean things up while I'm in there.
In a search of the forums, I didn't get any idea that this is a common thing, but I have an open mind and would be ok with someone suggesting that the oil is coming from somewhere else. There are some pictures attached, to describe what I mean.
Thanks!
-dant
Thanks!
-dant
