They are brembo 4 or 6 pistons...the manuel says...what brakes...need more info.
So they i would have to put my rear wheel up front and the OEM m5 wheel in the rear? I was thinking of doing that. Like i said the car wont be moving, i just need for it to be stationary hahaFront will need spacers for the 4 piston. Rears will clear, but you'll have like 2-3mm of clearance.
Yup... you would need a 19" wheel to clear those then. What exactly are you trying to do? :dunno:jesus...what a PITA...does NOT fit. I guess i have the 388mm 6 piston one, the wheel wouldnt even sit on the hub.
Basically one of my DPE wheels leaked air. And since i have a BBK, the valves are shortened, so you need a special valve to screw into it in order to pump air into the tire. So basically what i was trying to do since i do not have this valve, is to take it to a tire shop that said would change the valves out to normal ones. So i tried to take the rear tire off of my DPE n pop them in the front, and put the OEM in the rear. I did not feel safe leaving a car on a jack for 2-3 hours :crying2: So now i have to think of something elseYup... you would need a 19" wheel to clear those then. What exactly are you trying to do? :dunno:
I dont have jack stands, just a jack. That supports 2tons i just bought from Kragen.Unless you have a 6.0 earthquake or a tornado blow through, four 3-ton jack stands would be more than adequate in supporting your vehicle for hours, days, or weeks.
