1 - 12 of 12 Posts
Do the stock front control and thrust arms have roundel logos stamped in them? I noticed over the weekend that the arms on my car have the Lemforder logos on them. The original arms on my M3 had roundel identification markings so I was expecting the same on the M5. Can I assume these arms have been replaced in the past? The thrust arm bushings also have contitech bushings in place. The ball joint boots appear to be in good shape.
I am trying to determine what components of the front suspension need to be replaced as I chase down a front end vibration under light braking. I currently have 107k on the car. My original plan was to replace the thrust arms with new Lemforder units. However, if the arms have been replaced relatively recently I may just replace the bushings.
Trying to remember? I have a set of new OEM arms at home sitting in my parts pile, will take a look when I get home in about 10 hours. I know the TRW tie rods have both roundel and TRW stamp on the OEM items, but just the TRW if not dealer supplied. The Hella oil temp sensor I bought you can actually see where the BMW roundel was machined off for second source sale.
I also think the Lemforder control arm bushings I bought had Contitech stamped on them? But the X5 bushings I bought had the Lemforder stamp. Lemforder makes the OEM arms for BMW. So they will have the Lemforder stamp if OEM, but also think there should be a roundel too if OEM.
On my 3/2000 build both the thrust and control arms have "BMW"and the part number. Also, Lemforder symbol and date code of 12/99. My original set of thrust arms had a set of Contitech bushings that were pressed-in and date coded 2007(X5??), I removed them in 2010, they were still in good shape. My current set of Lemforder thrust arms had Boge bushings, I doubt they lasted 10K miles before the thrust bushing split off the side(crap). Just pressed in Powerflex bushings. I would not bother to install that Boge crap in my car again. See pictures of arms.
if the arms have been replaced I would think it's either ROTOR DEPOSITS or STEERING RACK
I've got the same issue on my car, everything is BRAND NEW except for the steering rack and I still get a shimmy under braking at ~50-70mph
It does go away if I go on a 100 mile drive were I get the chance to clear the pads and rotors with some hard braking. My daily commute is very docile and the brakes probably never get up to a good temperature.
EDIT:
14/July/2015
My shimmy was caused by my H&R 5MM spacers
5mm is the middle option for the smallest-spacer (3mm) and next largest-spacer with a built in hub (10mm), what happens is the wheel becomes Bolt-Centric instead of Hub-Centric so you will get a shimmy/vibration/shake at certain MPH.
I've not tried 10mm spacers because I saw multiple people reporting that H&R has a design flaw in the 10mm spacer (ONLY the 10mm AFAIK). The built-in hub is NOT flush with the spacer resulting in the wheel NOT sitting flush and yet-again NOT hub-centric
OP I checked my extra sets of control arms and the OEM ones have BMW & the part # on them, just like PrescottM5's pictures show. On the other side of the arm where the BMW mark is you should see the Lemforder triangle. The Lemforder equivalents I have are identical, but blank metal where the BMW casting is on the OEM ones.
I've found most of the front end shakes on these cars are caused by a combination of worn part(s) AND marginal wheel balancing.
Thanks for the pictures and input everyone. So that confirms that my front control and thrust arms have been replaced. Likely somewhere between 75k and 100k miles (when I acquired the car). The PO bought the car from EAG, so maybe they did some of the work.
I will look at the center link and tie rods, but I don't feel anything else that would lead me to believe the steering linkages are worn. Here is an outline of my issues:
- Brake judder above 50mph under light braking
- Under heavy braking no judder
- Shaking felt in steering wheel, minimal vibration feel in brake pedal
- Front end otherwise stable when pushed
- Inconsistent, sometimes strong shaking, sometimes none (potentially a sign of deposits?)
I'll look at the pad deposit issue on the rotors again. I flushed the fluids about two months ago, but didn't notice what kind pads are on the car. The rotors are cross-drilled centric and lines are goodridge braided stainless. I've never been a fan of cross-drilled rotors, I could swap some OE blanks and re-bed the pads to see how that helps.
I have cross-drilled centric rotors aswell + stoptech pads
I too would've preferred the slotted rotors
Yeah if you have judder, probably brakes. Double check wheel balance if you haven't already done so. If you have a spare set of OEM disks then worth a try for sure. In the past I've lightly sanded used pads on a large flat board to re-surface them prior to trying them on a different set of discs when hunting front end shakes. May cut down on the pad bedding in time.
I also meant to add earlier that the non BMW Lemforder arms I have, have Contitech bushings in them, that came from Lemforder. So Conti & Lemforder are partnered in some way. Box the bushings came in said Lemforder.
Discussion Starter #12
Wanted to follow up on this. I havent had the vibration for months. It does appear pad deposits were the issue. I went through the pad bedding process several times and haven't had this re-occur.
1 - 12 of 12 Posts
