Hello just thought i share my running report for the last 4 months. Firstly what a great car i had wanted one for a long time, but the running costs allways put me off.
The car i purchsed is a 1994 6 speed imported form Germany by munch legends in 1999. I had the car inspected by Pmw a independant specialist in Essex and they found a front edc shock was needed and the air con electric fan was seized, but apart from that a good car. The last owner payed for a new edc shock and i was left with paying for the fan.
First word of caution Pmw said this was a difficult job. So I changed the fan myself ,but it still did not work Pmw then said it must be the fan switch so i fit one of those but still no joy, they have the car again and decide its a bad earth and rewire the fan still no air con though. Next regas the air con it worked for one day
) ) back again to Pmw and as you can see my confidense is starting to waver , the next thing they want to change is the evaporator under the dash (6 hours labour) because they filled the system with green die and connot see it leaking anywhere else.
At this point i had decied to replace the radiator as it looked very old. On removing the old rad not only was it adout 70% blocked but guess what i find the condenser has adout 6 areas of green die leaking out.
So the new radiator has made the car run alot better the fan cuts in much less a new condenser was fitted by my new friend at Lind Bmw and i have working air con. My new friend also replaced the pollen filter and the fan blows twice as hard . He said he is willing to work on anyone else's m5 if they are having problems, the only problem i can see is that you do not get any paperwork as he works on you car on the side. But you get a Bmw trained person and Bmw parts and Bmw Knowlege.
The other things i have changed on the car rebush the rear subframe change to Avo sport spring 30% stiffer 20 mm lower, new brakes all round Haywood & scott stainless steel exhaust (very loud) custom air filter.
I have read the coments about fitting cone filters and the lack of inprovement they offer. I have used a K&n racing cone filter rated at 370 bhp and first of all the car performed worse, so i removed the mesh screens in the air flow sensor and then perforated the front of the car around the head lights. I have kept the filter sheilded from the hot air in the engine bay and feel the car know performs much better, still pulling strong at an indicated 165 at 6450 the other day then run out of straight road.
Two new problems have arisen one easy one not so easy
first a oil on the front of the engine cured with a new oil cap (£2.52)
second the suspension level fault on the dash comes on after 10 mins of driving, Bmw have checked the car and no faults are registered in the system the think it faulty wiring as the loom is know to break near the rear diff. So for the moment i have to live with it, but it would make it interesting if i was selling.
Any way happy motoring and i hope some of you enjoyed my rambellings
woodbig G :M5launch:
Do you guys from around London ever meet up ?
