Before you go catless, consider talking to Clemster about used cats from his fleet of donor vehicles.
Thank for this. In the end I just replaced the cats with high flow cats. We fired it up with just the resonator and it was WAY too loud. Like almost insane. I'm not going to say I didn't like it, but I also don't want to wake up the neighbourhood on my way to work.The general consensus is spacers can work to cure the B2 and B3 code but not to go catless. Also no two cars seem to be the same. You must adjust them to make work on your car. If they work for B2 and B3 you should be able to make them work catless.
What province? Almost all provinces have enviro cops and it is easy to get caught because of the smell. Ontario and Quebec are the worst for getting busted, and the fine will shock you. Not sure you will be able to tolerate the smell yourself.
Anyway longer spacers with two chambers seem to do the trick, I played with them a lot. I would use spark plug anti fowlers. It takes two per side one has to be cut short to get the whole length to fit. The cut one goes in the exhaust then the other screws into it, then the sensor. You have to have it all together to get it in.
For no cats you may need to experiment, but I would start with a larger hole in the one that is in the pipe to get flow then slightly smaller hole in the top one. The two chamber design gives better simulation of readings. All that said you need to have a tool so you can watch what the readings when you make adjustments.
Do you think it would work on BMW M6 e63? I mean the spacers from CEL perspective (with OEM cats)The general consensus is spacers can work to cure the B2 and B3 code but not to go catless. Also no two cars seem to be the same. You must adjust them to make work on your car. If they work for B2 and B3 you should be able to make them work catless.
Yes it would work but hitting the right length and the right size of hole is done with experiment. I have no idea if you have the space or what might be required. There are spacers that turn the O2 sensor 90 and have mini cats in them, they are not cheap but work well on first install.
