1 - 3 of 3 Posts
Welcome to the board....
I have the AA CAI, but I have modified what they provided...
- Does the tubing go into the stock air-boxes? YES
- Can I keep stock air filters? YES
- Do those new openings in the lower grill feed both the CAI and brake cooling ducts? YES if you cut openings in the lower fender liner.
I did not use the brake cooling feature as IMHO the air flow does not reach the rotor and does no real cooling unless you install ducted backing plates. I connected the air hose directly to the air funnel in the grill to have a true Ram Air effect.... no air leaks, real pressure all the way to the valves.
Sound like you are starting down the slippery slope.
Best of Luck
1 - 3 of 3 Posts
