Hey fellas,
Below is a link I thought was interesting while doing some research on my freshly acquired, "no start" issue.
As some of you know, I DID have the M5 going after installing the Simota Cold Air Intake and while it sounded rough, it ran. Last night, I started her after adding 5 gallons of fresh premium. I had previously ran her out of fuel. It started with no trouble again. It was running extremely rough however and there were both heavy visual and aromatic signs of thick exhaust. It eventually went into a low idle, shook quite noticeably and stalled. After this, starting became impossible. The engine would crank and try very hard to start, but would not.
Of note, i did replace some vacuum lines on the car last summer and was able to see the system perform its self check through movement of the resonance flap at start up. Prior to this, the self check had not been operable. NOW, I've noticed the system does not run through its self check and the resonance flap NO longer cycles through its self check. I don't know if this fault is correlated to the problem or not, but I have a hunch it may be. Any thoughts appreciated. I plan on carrying through with some of the troubleshooting procedures listed below when I am able.
http://www.bimmerforums.com/forum/s...showthread.php?1615162-THE-DEFINITIVE-%93NO-START%94-trouble-shoot-instructions
