1 - 4 of 4 Posts
today i was driving, and all of the sudden no reaction from the engine, everything was normal, no ses, no failure codes in the dme, pulled the car over, idle was normal, and pedal reaction to ,
is this ever happened to someone here ?
Could be the DSC kicking in if the ground was slippery!?
nope;the dsc was off,
it was limp mode, but immediatly restored itself, i had it again yesterday, i suspect it's the maf sensors, the car strumbels below 2000 rpm, when disconnecting the left one, i get very bad engine sound all over the rpm range, it's even better when i disconnect both maf sensors, i have NO error codes stored,
i replaced the MAF sensors and one oxygen sensor, everything is ok,car pulls much harder,without any hesitation, exept, the engine is stalling somethimes, when returning to idle , i suspect a faulty idle control valve, idle goes somethimes up and down before stabilizing the idle, typical symptom for a faulty idle valve, anyone ever had problems with that valve ?
1 - 4 of 4 Posts
