1 - 14 of 14 Posts
I recently sent out my cluster for repair to Doctor Bimmer at Pixel Repair NW and left the car unused for about two weeks. I received the repaired cluster and found that the car was completely unresponsive (e.g., no alarm, power unlocking, etc). I figured that something must have drained the battery. I reinstalled the cluster and put on my Battery Tender for about 12 hours. I came out in the morning and the car was still unresponsive (still no power locks, etc.). When I put in the key and turn to position one, all I can see is the airbag light barely illuminated. At this point, I figure that battery still doesn't have enough charge.
I've now taken out the battery to charge it in the house to eliminate the possibility of a system draining the battery while charging. What is interesting is that the Battery Tender is showing that the battery has 80% or higher charge (the green light is flashing). The red light is solid, which means it is charging.
I'm a bit stumped as to what I should be checking for next. Thoughts?
The only oddity that I noticed is when I disconnected the highlight switch, all the low power dashboard lights that illuminate the buttons, etc and stayed on. When I plugged it back in, the lights turned off. I left the highlight switch plugged in while the cluster was being repaired. Nothing else was modified on the car since the cluster removal.
Thanks.
Interesting. When I removed my cluster I plugged back in the light control switch and the tire pressure switch. Not sure if that helped or not but I used it for a whole week and no problem with power.
Company Representative for Valley Motorwerks
The battery was probably drained too far and will not recover. If you get the same result after charging in your home I would just get it replaced under warranty. It is a free replacement when it is this new.
^ Yep - doesn't hurt to try a new battery since it can be replaced under warranty.
Thanks for all the feedback. After a little bit of runaround on the phone, I managed to get in touch with the local Interstate distribution warehouse for my area. They were very helpful, great service. I brought the battery to them and it failed the load test. They gave me a new battery and receipt and I was on my way. The new battery works great and the cluster repair looks good as well.
So problem solved?
Discussion Starter · #8 · (Edited)
Yes, all set. The drained/defect battery was only outputting half (6V) of what it was suppose to (12V). Interstate replaced it immediately once it failed the load test. I was fortunate the local warehouse had two in stock.
Discussion Starter · #9 ·
FWIW, I'm still a little surprised that the battery drained so much in a little over two weeks without use. Not sure if anything was related the removal of the cluster.
Am I the only one not surprised? With the cluster removed, it's likely that you car never went to sleep. Without running it for two weeks, I would fully expect that your battery would be flat dead. Even a fresh battery isn't likely to recover from that. I have a stack of them over here that died before their time.
Discussion Starter · #12 ·
That's what I'm curious about. I do not recall seeing anything in the cluster removal instructions about using a trickle charger or plugging any of the disconnected switches. I'm hoping that I can spare someone else a rather unpleasant surprise if they need their cluster repaired.
Guys, I'm hoping to do this over the next few weeks.
Can we establish a good procedure? Mine is sat on a CTEK in the garage, do I disconnect charger, remove cluster, and reconnect charger, in that order?
Most battery chargers won't actually turn on and start charging till they see a load, if you connect a totally dead battery they won't start charging. I've had to connect a good battery to the totally dead one with jumper cables, then connect the charger and charge for an hour or so to get the voltage up a bit. I purchased a solar charger that will hopefully keep my car alive longer.
1 - 14 of 14 Posts
