1 - 20 of 25 Posts
There are no holds in my front bumper, do I need to drill to put in front license plate cover?
-Kmac
ok, so no license plate it is....
I can just see me drilling off center....
Zip tie the plate to the black grille beneath the bumper, and put foam on the back of the plate to prevent damage to the paint.
Reactions: Kmac
i put dynamat on the back of my plate (both front and rear). rear so it doesnt vibrate from the m-audio subs... but front so when i install it for long road trips i do not risk damaging/scratching anything.
I didn't think the M-Audio subs were good enough to cause plate rattle. Maybe I should test mine out.
I am relocating to a state with front plates. I am so no happy about this.
I've never had a front plate on - & here it's required.
Generally, the police have better things to do, like enforce illegal immigration, oh, wait, it's Mass, never mind ;)
So long as you 'show' the plate at the inspection process, you'll be fine.
I may or may not live in an area called Massachusetts that requires front plates and I may or may not temporarily install it with twist ties during the inspection process only.
Of course, Mass is a bit of an exception - if you have an old plate you still only have 1, it is only the new plate applications that get 2...
d-
Where can I get a licence plate bracket. I live in a front plate state as well
NYPD can be a pain with it, but in LI they got better things to do. I have been stopped but they just run my license and tell me to put it in on the windsheld. knock on wood
You mean they're are other things that they can do besides harass innocent people?? 9 out of 10 times they say "Well buddy, we pulled you over because this car fits the description of a vehicle used in a crime an hour ago". Then the usual, they pull me out sit me on my back bumper run license, registration, even the VIN sometimes!!!
1 - 20 of 25 Posts
