1 - 16 of 16 Posts
Premium Member
Nitrous oxide is an oxygen accelerator....not typically used for cooling in NA powered cars. Turbo/SC cars, its sometimes sprayed onto the intercooler to aid cooling, but they usually use methanol injection instead. I dont think that they have their facts straight, as I have a hard time believing they'd allow the use of nitrous in cars that crash regularly (not to mention the fact that its impossible to police)
Premium Member
NO2 also is used to cool the combustion chambers and lower intake and cylinder head temperatures allowing for higher compression/timing/boost
used for both NA and F/I engines
cooling is only an ancillary effect....its the oxygen acceleration that makes the power. its also impossible to police, and extremely dangerous to carry on a racecar
Premium Member
thats what I was thinking, they might only be using nitrous for cooling purposes only
They do that on FI cars a lot...the only issue is that when they spray nitrous into the intercooler it tends to drift off into the intake, giving unmetered nitrous oxide to the engine (could result in a big boom)
They don't have intercoolers since all F1 Engines are 2.4 Litre naturally aspirated engines .
The do use compressed air for the pnuematic valves. These engines can rev to over 20,000 RPM (although limited by FIA to 19K RPM) and normal valve springs could never handle that so they use Pnuematic valves. Could be they are using Nitrous instead of compressed air or CO2 to power the pnuematics? Doubt it.
Nitrous would never be used for engine cooling (too heavy and expensive). Cooling occurs as the car is driven through the air (no fans).
I think that site has their facts wrong.
The Sauber-BMW site has no mention if Nitrous... http://www.bmw-sauber-f1.com/en/#/car/factsheet/
Except in F1 since they do not have intercoolers... :hihihi:
Cool...
Hey, nice car :byee55amg
1 - 16 of 16 Posts
