1 - 2 of 2 Posts
As with a lot of people on this forum I am extremely anal when it comes to my M5. I self maintain most of the time and I am a stickler for detail and any problems I have I can't really rest until they are rectified. As a result whenever I self service the car I pay for a BMW specialist to check her over and give me a list of items I should watch/sort out.
My list is as follows:
1 - Slight leak from o/s diff output shaft seal - after discussion, we decided it wasn't worth doing until the car needs a new clutch, and this might be a job for him rather than me.
2 - Slight leaf from diff input CV joint - as previous
3 - N/S/F brake hose twisted - this came up last time and we forgot about it. I have kept an eye on this and there are no indications of wear in the last 15k. However at the next fluid replacement I will replace this pipe at the same time. Although at first we were concerned, due to the lack of any change in 15k miles we'll do this when convenient now.
4 - Slight wear in alternator belt tensioner - I will have this on order next month to carry out the replacement, is it worth replacing anything else while there? I was going to do the belt at the same time.
5 - Small amount of grease leaking from rear upper control arm outer ball joints but no play - I will get these done when I have the brake pipe done.
6 - Very slight play in N/S/R anti roll bar link - I have already replaced both links
7 - Exhaust downpipe bolts rusted - new bolts on order for replacement
8 - O/S/R axle carrier bush safety plate distorted - has anyone done one of these? It looks easy to do and I have the part on order, any advice on how to proceed?
9 - Coolant strength stronger than normal - coolant sorted and strength now normal
10 - Recommend gearbox oil replacement - will do this at the same time as the brake pipe, fluid and also ball joints.
On my own list I have added
1 - Chain tensioner replacement (on next oil change)
2 - Replace rear PDC sensors (painted ones)
Generally speaking I think the car is in great shape, the specialist even commented that really it was hard to find anything wrong with it and it was mostly just nit picking.
Thoughts?
My thought is....I need to get under mine to check general rear seal/propshaft/diff situation, too many people mentioning slight leaks and issues around here than I would like. If that's all that's amiss chap, you've got a good one :)
1 - 2 of 2 Posts
