Busy thread...
MIB,
I can only comment on the clutch chatter from inside the cockpit with a raised idle. I did this in my driveway, parked, holding a steady rpm. I did this at 900, 1000, 1100 rpms. I still could hear chatter, although it was reduced. Its not rocket science. Your right, I care less about the noise than I care about pure performance, but may chip the car down the road. The reduced chatter will be a positive side effect of chipping as I would do it for other reasons.
As for the clutch thoughts, I did note to "keep in mind I only have 1600 miles on the car". I very well know it doesnt conclude much other than the break-in miles and some good beating afterward it has managed well. You will use a clutch on-track more agressively than on the street, especially in a car that is not a racecar where clutch pressure and engagement is much higher/harder than the M5's soft "benign" pedal. PS- If you can rev match every shift on-track with this car's clutch setup and not get some slippage, your definately better than me!
Bri,
April is too early for me especially your dates cuz I am having surgery on my go pedal foot april 1st, and will probably be getting out of a cast that weekend! My next event will be in the Viper for the SCCA races the weekend of May6-8!
Front camber: I definately have it. Keep in mind I inherited the suspension from the previous owner so he may have done something to get more but I highly doubt it. I have the history of alignments performed on this car and the last one was 1.9L 1.7R Fronts...I didnt like the rest of the setup so I had the alignment changed based on some searching on this forum on Dinan stg3 setups. I didnt like that spec so I upped the front camber and dropped the rear to 2.2...I read somewheres that 2.5 was recommended. So I asked for 1.9 up front on both wheels and they did it. Have the printouts, but dont have a scanner at home....
Dave,
Thanks for all the pad history and info! I got my track pads from Dave Z. He did help alot! I said PFC01's werent available, but was hoping that someone would prove him wrong (never hurts to ask).
DSC on? How the hell could you track a car with it on? I forgot to turn it off one session and didnt get past turn 1 without it going crazy. I thought the car had a problem with the motor. Lol.
I hope someone can shed some light on the camber mystery, and Rob I'll give you a call - got your PM.
