I replied to the SPEC poll thread, but figured I would start a new one that had the specific topic heading:
I put in the stage 3 SPEC Hybrid 3 weeks ago. New version. Kevlar/Organic hybrid. I will have around 1,000 miles on it by tomorrow. I am taking the car to VIR Virginia International Raceway to see how this car performs on a 3.3 mile roadcourse...I'll give ya'll a report then if you want it...
So far the clutch feels good. Oh yeah I opted for the lightweight flywheel too. Chatter is obvious outside the car but I think everybody already knows that. As for durability of the clutch, we shall see.
Bought from Ben at Rogue. Nice guy. Total I believe was 1750 or thereabouts.
By the time I get back I should have about 1,500 miles on the clutch/flywheel combo, with 200 miles being hardcore track time if weather permits. I hope the stock brakes hold up (Stock hardware with race pads, complete brake fluid replaced with superblue and powersteering as well, and stainless lines)
POST TRACK WEEKEND.
Clutch and flywheel now have about 1,600 miles on it. They also have 2 days and eight hot sessions around VIR fullcourse. Just got back (225 mile trip) home and everything is fine. Clutch/flywheel worked flawlessly. My issues started out as a VERY BAD brake shutter that took 3 full sessions to go away. I originally thought it was a warped rotor, but ended up most likely being the conversion of street to race pad. Hawk HP10's.
By the second day I had no issues, and simply enjoyed flogging the car to the limits of the brakes, suspension and tires. Some observations:
1. Stock braking is not too bad. I honestly didnt expect the car to stop as well as it did for its weight, and stock pilots. I did get brake fade with the Hawk HP10's after awhile, but they held up pretty good. Overall an "OK" pad. Not great bite, but decent. I have not had the wheels off to check wear on the pad or rotor. Can anyone confirm or deny if the PFC 01's have a pad that fits our stock caliper? Its basically the best pad out there for the track.
2. Dinan Stage3 Koni suspension is not a poser mod. Its a little soft (anyone know the spring rates?) but its very compliant over gators and doesnt let the chasis unsettle in less-than-perfect transitions. Its a very good compromise street to track. I was on firm setting. I had the shop dial in -1.9 front, -2.2 rear camber. 6.0 castor with .20 total toe. My feeling is that I could/should have dialed in more camber up front. Anyone agree/disagree?
3. Pilots are probably not a good choice for track use, but not unusable if you want to go have fun. They will keep you out of trouble, but do go away quicker (push) each session if you run multiple HARD sessions in a day. I felt that 42 pounds hot was a decent pressure with ambient outside temps around 50 degrees.
4. The UUC shifter that is installed in my car has a dead spot left of second gear!?! Is this normal? What I mean is that There seems to be a place right below reverse that you can "attempt" to put the shifter in, left of second. Under quick downshifting manuvers I tried to put the car in second and missed the gate to second and hit this deadend....New to me.
5. The stock LSD is decent for high speed sweepers, but a variable lockup or quaife would be nice for powering out of slow, tight exits. First gear in the M5 (which I really like) really necessitates a quaife type unit. Probably a mod for hard-core track rats, or guys that want everything offered the car. Is there a swap out there from another model/year that can be used?
Im not sure of all the issues of the previous SPEC clutches, but I dont seem to have any. Keep in mind I only have 1,600 miles on mine, but I did baptise it by fire.
My car has 87,000 miles on it. Bought it 3 weeks ago knowing the clutch was fried. The Dinan mods were obviously done by the previous owner. Pretty **** impressive car to flog it like I did and have it perform so well. THEN drive a couple hundred miles home! Whenever I get a little nitpicky about some of the performance aspects I had to tell myself to quit comparing it to my racecar...900 pounds lighter, on Hoosiers, and with a power/weight ratio of about 7. Once I put it in prespective I just shook my head and smiled. Really was amazed at the performance of this sedan. :M5thumbs:
Hope some of this helps....Sorry for the obnoxiously long post!
