1 - 20 of 31 Posts
help! I was travelling on i-5 in Seattle the other night, on the 2nd evening after a fresh oil change (Royal Purple) over from Quartz. My last change was inspected by Blackstone Labs and all clear. 160,000 miles on this 2008 beast!! I used an indy garage this time who seemed very familiar with the model. btw... this car is running a stage III dinan tune, dinan air boxes, supersprint headers and full meisterschaft exhast from the headers back. (it's insanely loud and screams like a raped ape.)
So - after 2 days (post oil change) of driving on max and 30 minutes after the start of this particular outing, i get a red dash, OIL BELOW MINIMUM and de-powered into limp mode. I immediately pull over (30 seconds) and not a drip under the car... I expected a bit of a flood but nothing. I could not see anything wet underneath or on the asphalt and layed there on the ground for 2 minutes with an LED headlamp.
I go ahead and journey the 2 more miles home, motor stumbling quite noticeably and I'm trying to keep the revs under 3k... wondering if I am melting my crank but the temp stays normal. I've been reading lately about the interior VANOS lines and wondering if that is it. In addition I am getting other INPA errors... I have a German version and if anyone can relate or help, much is appreciated.
This list of errors is pre-clearing them and Google translating... I assume I will always be running cat codes without my catalytic converters. Can anyone tell me what tool to use to diagnose the lengthy "2 digit" codes?
F E H E R S P E I C H E R L E S E N ---------------------------------------
Date: 03.01.1980 23:22:46 JobStatus: OKAY Version: MS_S65_2.PRG Version: 2.000
RESULT: 16 Error in error memory!
0x2789 Catalyst Conversion Bank 1
P0420 Catalyst system (bank 1) - efficiency below threshold
Frequency of errors: 12 Logistics meters: 40
1. Environment kilometer distance 236800 km engine speed 2464.00 rpm relative filling 0.25 - CAT diagnostic value B1 2.91 - KAT conversion B1 and B2 1.11 -
2. Environment kilometer distance 238032 km engine speed 2877.00 rpm relative filling 0.37 - CAT diagnostic value B1 2.67 - CAT conversion B1 and B2 1.64 -
3. Environment kilometer distance 257752 km engine speed 3105.00 rpm relative filling 0.40 - CAT diagnostic value B1 3.11 - CAT conversion B1 and B2 1.26 -
Value above Threshold Test conditions fulfilled Fault presently present, OBD debounced Error would cause the warning lamp (MIL) to light up
Error code: 27 89 E1 04 20 0C 28 73 A0 09 A0 09 B9 BA 6B 47 25 74 3A 0B 3D 0E 44 AB 05 69 3B 7D DB 0C 21 0F B4 C7 11 50 77
0x278A Catalyst Conversion Bank 2
P0430 Catalyst System (Bank 2) - Efficiency below Threshold
Error rate: 42 Logistics counter: 40
1. Environmental distance Mileage 236888 km Engine speed 3102.00 RPM Relative fill 0.33 - CAT Diagnostic value B2 1.14 - CAT Conversion B1 and B2 1.26 -
2. Environmental distance Mileage 237080 km Engine speed 2384.00 RPM Relative filling 0.22 -
CAT Diagnostic value B2 1.15 - CAT Conversion B1 and B2 1.65 -
3. Environmental distance Mileage 258720 km Engine speed 3244.00 RPM relative fill 0.38 - CAT Diagnostic value B2 1.13 - CAT Conversion B1 and B2 1.20 -
Value above Threshold Test conditions fulfilled Error present not present, OBD debounced Error would cause the warning lamp (MIL) to light up
Error code: 27 8A A1 04 30 2A 28 73 AB 0C 1E 0C C7 48 E9 50 66 73 C3 09 50 08 84 49 6D 69 6D 7E 54 0C AC 0E B1 48 6D 4C 86
0x2B59 Coolant thermostat monitoring FS_LESEN_DETAIL: IFH-0010: DATATRANSMISSION TO CONTROLUNIT DISTURBED
0x2B53 Additional oil pump bench 2
Error frequency: 1 Logistics counter: 40
Mileage 239536 km Engine speed 4091.00 rpm Filling ratio 0.08 - Engine temperature 76.80 ° C Battery voltage KL87 13.70 Volt
Line interruption Test conditions fulfilled Fault present, not yet OBD debounced Fault does not cause the warning light (MIL)
Error code: 2B 53 44 00 00 01 28 74 F6 0F FB 02 F9 0D AC 00 89
0x2B63 INDEX_107_IGN
Error frequency: 1 Logistics counter: 13
Mileage 257664 km Engine speed 899.00 rpm Filling 0.56 - Engine temperature 21.60 ° C Battery voltage KL87 125.00 Volt
Value below threshold Test conditions fulfilled Fault presently not present, not OBD debounced Fault would cause the warning lamp (MIL) to light up
Error code: 2B 63 82 00 00 01 0D 7D D0 03 83 16 04 0B 84 04 E2
0x2B4E Combustion Exhaust several cyl
Fault frequency: 1 Logistics counter: 9
Mileage 257664 km Engine speed at misfire 849.00 rpm Filling at misfire 0.55 - Ignition angle Cyl1 at misfire 1.10 ° KW Integral ion conductance Cyl1 at misfire 0.00 nSs
Multiple Expanders 1. Cycl. Test conditions fulfilled Fault presently not available, not OBD debounced Fault would cause the warning lamp (MIL) to light up
Error code: 2B 4E 84 00 00 01 09 7D D0 03 51 15 9A 00 0B 00 00
0x27C1 InfoTank blank if error occurs
Mileage 257664 km Tank fill level 3.00 L Encoder value right tank capacity 3.00 L Lateral acceleration DSC 1.02 m / s * s Fuel pressure relative 6.12 bar
Sum filling level low Test conditions fulfilled Error present not present, not OBD debounced Error does not cause the warning lamp to flash (MIL)
Error code: 27 C1 02 00 00 01 09 7D D0 00 06 00 06 00 29 17 E7
0x2AFA Coolant temperature sensor Plausibility
Error frequency: 1 Logistics counter: 36
Mileage 259320 km Engine speed 4577.00 rpm Air mass flow B1 and B2 347.70 kg / h Engine temperature 62.10 ° C Cooling water temperature Model 75.70 ° C
Sensor hangs Test conditions fulfilled Error presently not present, not OBD debounced Error would cause the warning lamp (MIL) to light up
Error code: 2A FA 82 00 00 01 24 7E 11F 11 E1 0D 95 0D 19 0D A1
0x27B1 Secondary system throughput bank 2
Mileage 259400 km OBD-SLS Standard deviation. Integral max 0.44 kg / h OBD-SLS Standard deviation. Integral min 0.26 kg / h OBD-SLS Standard Lam deviation. Integral 0.88 - * s Ambient temperature 16.50 ° C
Line Bank 2 leaking
Test conditions fulfilled Error present, not yet OBD debounced Error would cause the warning lamp (MIL) to light up
Error code: 27 B1 C8 00 00 01 28 7E A9 01 B3 01 06 38 64 0B 51
0x2748 Lambdasonde Diag.ueber ATIC42 building block VKAT Bank1
Error rate: 98 Logistics counter: 40
1. Environmental distance Mileage 259400 km Motor speed 1200.00 rpm ATIC42 Diagnostic byte probe VKAT B1 8.00 - ATIC42 Diagnostic probe VKAT B1 0.00 - Battery voltage KL87 13.70 Volt
2. Environmental distance Mileage 259400 km Motor speed 4515.00 rpm ATIC42 Diagnostic byte probe VKAT B1 8.00 - ATIC42 Diagnostic probe VKAT B1 0.00 - Battery voltage KL87 13.70 Volt
3. Environmental distance Mileage 259552 km Engine speed 1263.00 rpm ATIC42 Diagnostic byte probe VKAT B1 8.00 - ATIC42 Diagnostic probe VKAT B1 0.00 - Battery voltage KL87 13.80 Volt
VP-LIMITATION Test conditions fulfilled Error present not present, not OBD debounced Error causes no warning lamp (MIL)
Error code: 27 48 02 00 00 62 28 7E A9 04 B0 00 08 00 00 00 89 7E A9 11 A3 00 08 00 00 00 89 7E BC 04 EF 00 08 00 00 00 8A
0x274A Lambdasoning pump current compensation error VKAT Bank 1
P2626 Lambdasoning pump current compensation line Circuit (bank 1, before catalytic converter) - Malfunction or line interruption
Mileage 259416 km Motordrehzahl 3684.00 RPM relative filling 0.08 - AD transducer probe signal VKAT B1 4995.12 mV corr filtered AD value probe resistance VKAT B1 1103.52 mV
IA_OPENLOAD Test conditions fulfilled Fault presently present, OBD debounced Error would cause the warning lamp (MIL) to light up
Error code: 27 4A E4 26 26 01 28 7E AB 0E 64 03 06 03 FF 00 E2
0x279E Oel quality sensor
Mileage 259544 km Engine speed 2705.00 rpm Engine condition TL 0-n Raw value Oil level measurement from the sensor 75.67 mm Battery voltage KL87 13.60 Volt
OEL level too low Test conditions fulfilled Fault presently not available, not OBD debounced Fault does not cause the warning light (MIL)
Error code: 27 9E 02 00 00 01 28 7E BB 0A 91 00 20 00 FF 00 88
0x2B49 Combustion Exhaust Gas Exhaust. Cyl
P0308 Incineration detected - Cylinder 8
Mileage 259544 km engine speed at misfire 2931.00 rpm relative filling at misfire 0.49 - ignition angle Zyl8 at misfire 24.90 ° KW integral ion conductance Cyl8 at misfire 9.45 nSs
End-of-day translation 1. Cykl. Test conditions fulfilled Fault presently present, OBD debounced Error would cause the warning lamp (MIL) to light up
Error code: 2B 49 E2 03 08 01 28 7E BB 0B 73 13 42 00 F9 01 E2
0x2B3C Incinerator with shut - off Cyl 8
Frequency of errors: 2 Logistics meters: 40
1. Environmental distance Mileage 259544 km Engine speed at misfire 3669.00 rpm Filling at misfire 0.21 - Ignition angle Cyl8 at misfire 46.40 ° KW Integral ion conductance Cyl8 at misfire 63.86 nSs
2. Environmental distance Mileage 259552 km Engine speed at misfire 1125.00 rpm Filling at misfire 0.54 - Ignition angle Zyl8 at misfire -2.60 ° KW Integral ion conductance Cyl8 at misfire 29.61 nSs
Encoder failure Test conditions fulfilled Fault presently present, OBD debounced Error would cause the warning lamp (MIL) to light up
Error code: 2B 3C E2 03 08 02 28 7E BB 0E 55 08 40 01 D0 0C B9 7E BC 04 65 14 EF FF E6 05 E6
0x2B57 Motorbot program activated
1. Environmental distance Mileage 259544 km Motordrehzahl 3661.00 RPM relative fill 0.21 - Battery voltage KL87 13.80 Volt SK Cause injection monitoring 0-n
2. Environmental distance Mileage 259552 km Motordrehzahl 1116.00 RPM relative fill 0.53 - Battery voltage KL87 11.60 Volt SK Cause injection monitoring 0-n
Injection fade-out Test conditions fulfilled Error present not present, not OBD debounced Error does not cause the warning lamp to flash (MIL)
Error code: 2B 57 02 00 00 02 28 7E BB 0E 4D 08 47 00 8A 00 04 7E BC 04 5C 14 AF 00 74 00 04 --------------------- -------------------------------------------------- --------
0x2796 Motornot program activated
1. Environmental distance Mileage 259544 km Engine speed 3662.00 rpm Filling 0.21 - Battery voltage KL87 13.70 Volt SK Cause injection monitoring 0-n
2. Environmental distance Mileage 259552 km Engine speed 1109.00 rpm Filling 0.53 - Battery voltage KL87 11.50 Volt SK Cause injection monitoring 0-n
Error code: 27 96 02 00 00 02 28 7E BB 0E 4E 08 4C 00 89 00 04 7E BC 04 55 14 A4 00 73 00 04 ========================================================================
After clearing with INPA, I ran the car for about 3 minutes in park and pulled them again. still no change in oil level... either the sensor is not working, or the interior hose is wasted... or I lost so much oil so fast that it is a new world record... here are the codes post clearing:
READ ERROR MEMORY
Date: 03.01.1980 23:49:46 JobStatus: OKAY Variant: MS_S65_2.PRG Version: 2.000
RESULT: 5 Error in error memory!
Error frequency: 1 logistics counter: 80
Mileage 259552 km Engine speed at misfire 1200.00 rpm Filling at misfire 0.55 - Ignition angle Zyl8 at misfire -3.10 ° KW Integral ion conductance Cyl8 at misfire 50.47 nSs
Final test conditions not yet fulfilled Error present, not yet OBD debounced Error would cause the warning lamp (MIL) to light up
Error code: 2B 3C D2 00 00 01 50 7E BC 04 B0 15 59 FF E1 0A 0E
Mileage 259552 km Engine speed 1187.00 rpm Filling 0.55 - Battery voltage KL87 13.20 Volt SK Cause injection monitoring 0-n
Injection suppression Test conditions not yet fulfilled Error present not present, not OBD debounced Error causes no warning lamp (MIL)
Error code: 2B 57 12 00 00 01 28 7E BC 04 A3 15 79 00 84 00 04
Error code: 27 96 12 00 00 01 28 7E BC 04 A3 15 79 00 84 00 04
Mileage 259552 km Engine speed 1814.00 rpm ATIC42 Diagnostic byte probe VKAT B1 8.00 - ATIC42 Diagnostic probe VKAT B1 0.00 - Battery voltage KL87 13.80 Volt
Error code: 27 48 02 00 00 01 28 7E BC 07 16 00 08 00 00 00 8A
End-of-day translation 1. Cykl. Test conditions not yet fulfilled Error present, not yet OBD debounced Error would cause the warning lamp (MIL) to light up
Error code: 2B 49 D2 00 00 01 50 7E BC 04 B0 15 59 FF E1 0A 0E
New Oil Change: 48 hrs later, OIL BELOW MINIMUM, limp, De-powered, rough and...
This is why I do my own oil.
I would do this: Drop out the oil and see how much it is. It feels like you did not have enough oil to begin with. It got so low the ECU deemed it unsafe. Start over and put 8 quarts in. Measured after getting it to temp and top it off to full. Measure again.
While you drop your oil out into a slanted flat black surface and look for metal flakes. If there is none you should be alright. Get a good oil catch pan. If you have flakes you are in trouble.
My estimation is that you had a major air bubble somewhere and Indy thought it was full but it wasn't. He did not top it off properly. Once the air bubble cleared you end up drastically below level. If you did not find oil below the car.
And by the way: Use stock 10W-60 oil.
Clear the codes. Drive it for a bit. If the oil was very low the system was sucking air and the VANOS could not adjust properly causing misfires. It is all about clean and enough oil in this car.
thanks rt7085 - I'm going to do just that (drain, measure and inspect for flakes) After considering towing it to a witness garage, I figured it would be nearly impossible to prove they did anything wrong but I would be more than pissed if they used another oil than what they promised.
Question for you: is the high pressure internal Vanos line a difficult swap? and after a recall wouldn't an 08 edition be fairly immune? Or, with this many miles should I expect a torn line?
Also - is there a readily available source for a dual vanos test-line and gauge? thanks!
An 08 should have the upgraded metal internal high pressure vanos line which are not known to fail.
Unfortunately Hasan, there was no upgrade. All years have the identical line internal and the forced flexure of the hard pipe to braided transition to clear the crank nose is a stress concentration point. Eventually, most all will leak.
OP:
Keep in mind the Oil Sensor works based off of conductivity. There are different algorithms based on the oil in use. For example, during new engine break in with break in oil, the DME is set not only for a 1200 mi break in interval, but the conductivity parameters are different as well. In your earlier error code read, there was an oil sensor error.
If it were my own car, I would drain the Royal Purple and fill with TWS or LM 10-60, one of the oils with a large use-case history here with little known problems.
OP:
Actually the oil sensor appears to work and I -think- it caused the limp mode. It is reporting a very low reading, at least, that is the way I read it. I have never tried this, but when it is very low, would the DME kick itself into RPM limiting? Makes sense.... The oil is very low: That why I think the engine run like crap because he was sucking air into his VANOS pump. So, cam adjustment were probably none to speak off, causing misfires. There are also a lot of codes that may have nothing to do with this issue. Such as the thermostat code. This engine needs a little TLC if it ain't damaged. I don't think it is. Just fill it up with the right soup.
Discussion Starter · #10 ·
has anyone made their own steel internal vanos line? with a couple buddies in the aerospace biz, they could bend me up a solid line pretty easily. Or, does the line have to flex in order to install it? I guess it's time I start watching some videos...
Challenge
Also I'd expect vanos codes if the pressure was too low to actuate the cam adjusters. All I'm seeing is cyl 8 misfire, limp mode activated and bad o2 sensor reading on the other bank.
I'd probably start with #8 - pull the plug and swap the coil pack around to see if it follows and drain the oil and refil the right amount.
Discussion Starter · #12 · (Edited)
So this is how long it takes for me to find time to simply drain the oil in my beast... I have no lift so it's always fun jacking and blocking the car. If it's the internal vanos line I'm going to be forced to take it to an indy so if anyone has a contact in Seattle with the experience of changing the rod bearings, I may as well do that too.
The car is full of oil. Thank God there is not a speck of copper in it... I guess that is the good news. What really worries me is that this garage I went to for the first time charged me $290 to do the oil and this is what came out of it after less than 6 hours and 200 miles of drive time...
https://drive.google.com/file/d/0B44zUJOFt19sQVk0Znh2d3NZSGs/view?usp=sharing
https://drive.google.com/file/d/0B44zUJOFt19seHd2Z01hZlBOWHc/view?usp=sharing
https://drive.google.com/file/d/0B44zUJOFt19sajI5UEVEWmI1eGM/view?usp=sharing
this doesn't look like brand new oil to me! It appears to be oil that is a couple thousand miles old... not 48 hours old. I'm going to send it to Blackstone and see if they can tell me how old it is... unless anyone can say "Royal Purple synthetic 10w-60 comes out of the jug looking like this!"
So, knowing that I'm full of oil and the car is reading OIL BELOW MINIMUM, is it indeed my internal Vanos line? And if it were your car would you even fire it up and let it idle, none the less drive it 3 miles to a new garage?
Thanks guys I appreciate your comments.
Discussion Starter · #13 ·
OMG.
I just emptied out the main sump, the forward sump and the oil filter.
16 quarts.
Rempt Motors in Auburn, Washington State, the indy garage I used for the first time who spoke with confidence and knowledge about the e60 m5, put more than 7 additional quarts of oil in my car above spec.
In fact, it looks like they never drained the oil... instead, simply poured a bunch more oil in my car without ever draining out the old. I'm flabbergasted! No wonder the oil looked so dark upon draining out... they never drained it at all.
I drove the poor beast for 1.5 days and about 100 miles, on 16+ quarts of oil in the engine... with an electronically displayed oil level of "MAX" with no other indication of overfill... you just got to love this! Without a dipstick, I cannot be the only victim of this, and am wondering if the garage would have done this to a brand new customer on purpose? Simply a ridiculous oversight? at best it is complete idiot incompetence.
I am now wondering what happens to an engine with this much oil pressure... blow-by? crank frothing and bearing failure? seals? ring damage? Would love to read your comments if you've ever heard of such incompetence or have any knowledge of what I am going to be dealing with?!!
Yes probably a lot of blow by and such causing misfires. It probably went everywhere and fouled up a lot of stuff. A lot of oil probably got in the combustion chambers causing all the lambda, cat and 02 sensor errors. You may need new 02 sensors and possibly new cats. Oil may have been forced backwards into your intakes as well due to the pressure in the breather check valves.
I would fill it properly and observe the issues for a while more. Reset codes. And see what evolves. You have to run the engine a bit more and see if will clean up a bit. But be prepared.
The coolant related codes are independent issues I guess.
What is your oil change interval? Unless your oil change intervals are really short like 3000 miles or so, your oil will look like this after a couple of days. Keep in mind that it is not possible to drain out all the oil and there is about a quart of oil in your oil cooler as well.
OMG.
16 quarts.
When the readout says >MAX, you're overfilled by MORE than 1.5 liters. Aka need to drain that shiz.
OMG.
16 quarts.
Horrified. They almost certainly caused permanent engine damage that could manifest itself a day, a week, or a year later. I would insist on them paying for a BMW-repair center to replace the engine. Lawyer up.
NEONGUY, This is an awful scenario, any update on the damage that was done as a result of too much oil? So sorry to hear that this happened to your beast!!
Discussion Starter · #19 ·
The Garage's owner denies they are any bit related to this (of course)... I understand as it would take a complete idiot to forget to drain the oil. He checked and claimed he only ordered 10 quarts of oil as he did not have the 10-60 that would be required, so he "could not have" added 16 quarts, and it was impossible that his tech "forgot" to drain the oil. Also claimed that yes, the color looks appropriate for running for a day or two.
He also claims that the oil level sensors go bad often and that could have helped delay detection... but the car only said MAX and nothing else.
He thinks I must have a stuck injector that managed to leak 7 or 8 quarts-worth of fuel into my engine in 48 hours. I cannot tell that the old oil is much less viscous, and BlackStone labs confirms they can identify additives from different oil manufacturers that may help in determining if indeed another oil is mixed in... so I am sending off the oil for a more detailed test to find out exactly what came out of my engine.
Post the Indy's name such that others don't use him. Come on! If you have stuck injector you would endure hydrolock. A complete cylinder destruction and engine lock up. He just reconfirmed to you that he has no sense of how engines actually fail or work for that matter. Remember: You cannot argue with a fool as they will outdo you with experience! LOL!
1 - 20 of 31 Posts
