1 - 20 of 20 Posts
Hi,
I got an 06 M5 Stck no mods.
Waked up a morning and started my M5 , Disaster Shown on the dash board info.
1. SOS system Failure.
2. Batery Over charged. error.
3. I-Drive screen not working at all DEAD. !!!
4. Left Mirror is turning to clockwised until reach to the maximum !!!.
tried to make CCC reset but no advantage. it is still dead not working.
Changed the battery as per the dealer said but still not working.
The dealer is saying that all the faults are coming from the CCC unit it must be changed.
i will change but they dont promise that it will work fine and as everbody knows BMW M5 Middleast version warranty expires after 2 years from date of first buy with no possibility to extend .
so Experts HELP with advices !!!!!
What should i do next?
First of all welcome!
2nd of all, Middle East M5's have a 3 year or 60k kms warranty. An option for extended warranty is available but it's very costly.
Let the dealer diagnose the faults and see what error codes appear. guessing is not going to help you! It could be your alternator for that matter. Anything is possible!
Ask them to diagnose the car and ask to see the error codes and post them here.
hi mate, welcome :)
any update on the issue? is it solved? feedback plz
Hi,
My Beast is still with BMW Dealer.
it is been 2 weeks and they didnt find the problems source
Latest feedback got from them is that they are trying to change the CCC and recheck if it solved and inform me.
Freinds, will let you know what happens further !!
Alternator intermittently overcharging
Alternator failure can throw some confusing symptoms.
Mine is at the shop right now. They discovered the alternator is intermittently overcharging. These intermittent faults can wreak havoc on diagnostic process. I got lucky. They read and reset all codes. They took it out and almost immediately it gave them the symptoms I described. They checked alternator output voltage and found it at 17.9V and then it went back down to 14.6V. I read the output voltage at 14.6V the night before too. I thought I had good battery voltage (but didn't load test it) and good alternator output voltage, but that was not the case!
Good luck!
Discussion Starter · #14 ·
i told them abut the alternator but they said they doubt that it is from alternator but it is from the CCC.
guys,
will let you know wht happens further with my M5
Good luck bro! Keep us posted on what happens!
guys,
Yes I saw that you had told them that. What I was referring to as something to keep in the back of your mind is that the alternator can intermittently demonstrate signs of failure. If they test the alternator and it looks good at that moment, they move on to the next likely culprit. If they get to the end of the line in troubleshooting, maybe an intermittent failure is something to check into.
Good luck getting this sorted out.
Discussion Starter · #17 ·
Hi,
Hi Guys,
Good News.
Just got back my M5,
WOOOOOOOOOW
Finally it is back on its track.
As per i Mentioned before, delaer asked to replace the CCC unit, when they replaced it and reporgram it.
the problems were Solved:
Uptill Now it is Fine, but the Dealer said that no worries Maan there is 2 years warranty on the unit in case of it get faulty.
Now, My M5 will breath genuinly as it was born new. :M5thumbs:
1 - 20 of 20 Posts
