1 - 3 of 3 Posts
When I was in the middle of having my exhaust installed, I was noticing the routing of the EGO sensor wiring under the chassis. The wiring seems standard from where it attaches to the exhaust, running up the chassis, but then I noticed something strange.
The wiring was secured via industrial zip ties to the shifter carrier! :eek: The wiring actually goes up past the propeller shaft, runs into the interior of the car through the rubber shift boot and then to a plug-in connector. This connector then runs back down across the carrier and towards the transmission area and then out of site....
So basically can someone tell me if this is a strange jerry-rigged EGO wiring, or maybe provide some under carriage pictures to compare it to?
Thanks in advance,
Jeff (is confused)
The O2 sensor lead should run over towards the driver side (LHD cars) and get routed/covered by a braket that turns and heads towards the front of the car. No zip ties, at least on my '88, and everything is beneath the car.
Thanks for the input.
I replaced the sensor this weekend, and routed it the way it should be routed. I have no idea wtf was with it previously. Considering the 02 sensor I pulled out of the exhaust was the original sensor, this was long overdue. Car runs like a beast now. Drivability, gas mileage, and power have all improved.
:cheers:
1 - 3 of 3 Posts
