1 - 19 of 19 Posts
Is it possible to do it without creating a CEL light on the dash? If so, how do I go about deactivating them and safely removing them?
Please no harping on removing safety features of the car, I know the risks. Most of the cars I have owned did not have them........
I would try various resistor values until the light goes off, try something ~2 ohms, seems to work for other BMW cars
Reactions: timmay77
Discussion Starter · #11 ·
Thank you everyone for the PM's and thoughts!
The new A Pillars should fit fine, I am just worried about IF they went off with them installed. I did build them so that the speakers were below the airbag, but I would rather be safe and not have them going off then to have them explode and take some of the speakers and fiberglass with them creating a nice blanket of shrapnel.
Discussion Starter · #12 · (Edited)
double post, sorry
IIRC there were 5'ers that came w/o the head airbags (early production models). Im sure it can be coded out. Question is will it actually let you.
It might depend on which airbag and/or general module revision you have (I have only done it once, just to see), but the short answer is: yes.
Discussion Starter · #14 ·
Ok, it was confirmed last night that I do have to deactivate the airbags. So if someone can point me in the direction of where the connector for the airbag is that would be great! I will then attempt to solder in some resistors.....
Thank you gentlemen.
Premium Member
The bright yellow ones...cant miss them. Disconnect the battery first (both terminals, and touch them together).
Discussion Starter · #16 · (Edited)
I am being told that the dash has to be removed to get to the wiring for the A Pillar air bags. Is there a way to trace it down to the footwells? Does anyone know the wire colors for them? I REALLY don't want to pull my dash.
all airbags use BRIGHTLY colored connectors, yellow or orange are the only colors i've seen. IIRC, the wiring tends to stand out, too.
1 - 19 of 19 Posts
