Need Help with Real OEM parts
2901 12
I love using Real OEM but I'm having some difficulty finding some of the parts I need to get part numbers for for my Front end Fix.
http://www.realoem.com/bmw/showparts.do?model=DE93&mospid=47592&btnr=51_2427&hg=51&fg=75
I need what I think is the Passenger side version of #14. But it doesn't seem to be listed, it is also the same components that holds the temp sensor. I also need the little cup that goes around the sensor (creates the well in the plastic), but not the sensor itself.
I'm also pretty sure I need #3 and #6, but they are not listed in the list of parts under the pic.
Any help?
Thanks.
Bob
1 - 13 of 13 Posts
Any help?
Thanks.
Bob
Part number 14 is listed four times, the second and fourth listing are for the passenger side - they refer to "right" as passenger side. WITH the brake duct cut-out the PN is 51712694832, WITHOUT the brake duct cut-out, the PN is 51712498990. The cup around the temp sensor is part of item number 14 - it's permanently attached, not separate.
Parts 3 and 6 are not listed because they're not M5 parts, and you don't need them. Perhaps you need #26 instead of #6? Maybe #28 instead of #3? You'll have to guess. What is the problem you're trying to fix?
I posted a thread a couple months ago about smashing a hole in my front bumper when I had a brain fart and didn't pay attention when backing out of my drive on a -4° day. In doing that I broke the front fascia and #14 on the passenger side. I also bottomed the car out real hard and broke the undercarrage plastic screen #9. That apperas to be pushed up and whatever the brackets that hold it on appear to be thin metal and bent.
So I get to spend a lot of money because I'm a moron.
Thanks for the help, I suppose if I read things fulley it would help me.
Bob
There are a lot of parts under there ;)
#20 is also a supporting bracket, and make sure you order an amply supply of the various sized screw plugs and clamps.
Oh, and in case you need it, despite what the picture shows, #13 is apparently the cover for the oil drain, not #22.
On the engine compartment covers, remember that we do not have brake ducts as standard although there are mods to add them - the M Package refers to an option on lower series vehicles.
Lastly, part #9 also has several screws holding it in place, so make sure you get them too :)
FWIW, we all break those parts as part of daily life. My temp sensor is presently exposed from when I ran in a curb at the front of a parking space...
d-
Discussion Starter · #8 ·
I may have the body shop guy get all the plugs and screws, I get discounted dealer parts through my aunt so I'm buying all the large expensive pieces.
If I get the brake duct versions of the covers (they are cheaper) will they fit on my car, even in a non functional state for now?
Thanks for the continued help, I appreciate it.
Bob
Discussion Starter · #10 ·
Oooh, dirt in the engine bay. That would suck.
I could probably search but is there a how too to put the rest of the ducting in? Do I even want to do it?
Bob
Bob
Yes there is a how-to. And I'm too tired to find it for you, so search for "open brake duct" :)
The general consensus is that if you are tracking the car you need a BBK and the brake ducts, otherwise you should be fine with stock.
d-
d-
http://www.louv.tv/cars/m5/ducts/
I did it for the heck of it when I put on the BBK
A
Discussion Starter · #13 ·
Awesome, thanks.
I'll order those air ducts right away too then.
Bob
1 - 13 of 13 Posts
