M5s do go through oil more quickly than many engines and you should definitely check your oil level at least every other tankful of gas. My 2003 used a quart about every 1200 miles or so when new and then settled down to one about every 1500-1600 miles now with about 10k miles on it. There are a number of threads about this issue on this board. I seem to recall that the older E39 M5s had 10w-60 as the recommended weight of oil while mine has 10w-30 as the recommended weight. Hope nothing is wrong with your beast!///MLOVER! said:Well guys im sorry to neglect my car but today i had a quite a scary experience and i dont know what happened and why yes im a total newbie to the M5. Last night check engine oil level light appeared on the dash i was on the way home when it occured. So i went to the nearest gas station adnn they didnt have 10w-60 oil as labeled as needed in my engine bay. So i go to start the car this morning the engine churns over but no go, i then run to a gas station and put a quart of 10w-60 engine starts right up. Now was this due to the oil level? or is there something wrong with the engine? Also, do i have to use 10w-60 oil in my car?. Its a 2000 M5 with 59,000 miles. Also, an oil change was done almost 2,000 miles ago, and the inspection lights are green. Thanks for the help!
-Lou
ChuckG :byee55amg
