I'm hoping someone around here has a solid background in electronics and might be of some help. Some of you know the solenoid board prices have jumped by 2-3x so I think it's time for those of us that are resourceful to come out of hiding and try to find ways around this absolutely ludicrous expense.
I had a variety of vanos-related codes for bank 1 from my '00 that has had a CEL for awhile. The car seemed to run 100% but I decided to replace the o-rings for that solenoid rack and test the individual solenoids in the process in hopes to eliminate the codes, don't have them handy.
Weeks ago, I used a 12v/2amp battery charger to test the individual solenoids via the pigtail leads using the handy diagram that another member kindly drew up (attached). I don't know definitively on polarity (or if it matters) but I used the purple and brown wires as common ground. Three of the solenoids worked fine and there was an audible clicking sound. When I tested the green wire (Solenoid 1 according to the diagram) it was sparking and seemed to be shorting out. I then tried testing at the solenoid itself and again was sparking and shorting, followed by a small plume of smoke that appeared to come from inside the solenoid... as far as I could tell. I figured the coil inside was toast and just finally gave out, or maybe I killed it. When I installed it back on the car it was running extremely rough. I drove it like this for a few weeks searching for the next plan of action.
I finally bought a replacement solenoid (just one) from Chris @ DrVanos (to the tune of $250) and had a good friend who does ECU repair install it last night. Install went well, I did not test the replacement from Chris although it appeared to be a used unit. I put it back in the car with new o-rings and fired it up and the car was back to running well again. Fantastic. I drove it for 15min down the street and back and then cleared the codes and fired it back up again and it was back to running rough again. F***. Frustrated, I drove home and crashed.
I pulled the solenoid rack this morning and tested again and found that the solenoid I replaced last night was again 'shorting' when applying 12v at the pigtail. I tested again at the solenoid itself, this time with a 5v/550ma signal from an old phone charger (after reading someone else's post about doing this) and nothing happened - no click or nothing... just some very small sparks at the soldering joints. I tested the other three solenoids and they worked fine using the same 5v signal.
The weirdest thing is I tested the OLD solenoid that I thought was bad directly with the 5v signal and I heard the piston moving this time. This made me suspicious that maybe the solenoid when soldered to the board in the circuit with the MOV may not work properly. Obviously the one that I thought was dead is in fact working fine.
I tried using a multimeter to check the impedance (ohms) at the solenoids but kept getting erratic results. I also tried testing the MOVs (metal oxide varistors) but got varied results; however, the first time I checked these the one in line with the solenoid that is not functioning was showing like 2-3 ohms and the others were 5-7 ohms so I'm starting to think that particular MOV is in fact FUBAR. I looked over all the other traces and could not find an issue. I know I can send it off to Chris (DrVanos) to check the whole board but it's my only car that I use on a daily basis.
My best theory: The first time I tested the solenoids I killed the MOV for the one I replaced. Still doesn't explain why the car ran momentarily last night.
Questions:
- Is there a way to check these MOVs on the board and get a solid notion that one or more are in fact bad?
- Does anyone know where I can find a replacement for the MOVs? If I can identify exactly what kind I need I'll just replace all four of them. I looked around on mouser.com but I have no idea what the specs are for the ones on the solenoid board.
- Another member mentioned the solenoids operate on 5v, not 12... thus the reason for the MOVs. If they are designed to limit the voltage (like a resistor) down to a usable current for the solenoids could they also cause the short that I am experiencing?
Thanks to whoever put together the drawing I attached for reference and thanks to Chris (DrVanos) for all your helpful and responsive emails.
Questions:
