hey guys wondering if one of you can do me a quick favor. the prerequisites are you have to have mich pss's and have had a recent alignment and are running close to zero front toe. on the pss tire the first outermost line is skinny and the end of a tape measure fits perfectly in it. on level ground if you can catch the one end in it and measure to the same line on the opposite tire, measurement should be around 62in give or take. easiest way to do it with one person is extend the tape measure and lock it, catch the end in line and jam it between the tire and the ground, then pull it to the other side. reason im asking is i installed a new center link and haven't had a chance to get it on the rack yet to set the toe. i measured the old one and set it to the same specs. i got the steering wheel straight and its doesn't pull at all but it tramlines on the highway which it never did before so i think i have too much toe out in the front. thanks
