1 - 9 of 9 Posts
My wife filled up the car last night, and swears that she used 91 octane. Today it seems to run a little more sluggish at high RPMS. If the car in fact had 87 would I hear knocking and pinging, or anything else funky?
Thanks, Hector Lopez
Super Moderator
probably not, the knock sensors should back down the timing to compensate for the lower octane.
Mike
According to the tech who works on my car, eventually the EMS will throw either a code or a light indicating "Improper Fuel Type" or something similar.
:cheers:
Jeff
Hector-
There are probably a few stations selling 100 octane gas in your area.
http://www.m5board.com/vbulletin/showthread.php?t=50783&highlight=100+octane
Prolly by the time you drove to one, you'd have enough room- 5.66 gallons of 100 added to 12.33 of 87 is 91 octane.
I'd be surprised if there were major driveability issues with JUST 87 octane- advance is retarded, a bit lower HP and it would run a touch hotter (i think)
A
Well, I think the issue is that IF you have 'sluggishness' or other issues, it might NOT be caused by the 87 octane (if, indeed, it was 87)... it might be something else.
Maybe you're imagining it- having been separated from the beast while the wife was permitted to operate it- can lead to all sorts of hallucinations.
A
Discussion Starter · #9 ·
Wow, you may be right!:7:
A
1 - 9 of 9 Posts
