rigsby said:
Yep happens all the time regardless of watching TV, sat nav, stereo controls, displaying computer etc.
What software level do you have? not sure if it'll help, but certainly worth a go, before getting the screwdrivers out. Settings -> Top right there should be a no like 3-1/63 etc.
If its at the latest version, could well be the screen itself :sad3: it can be changed separately to the tape/cd/mini disc deck behind it.
You could also check the 2 plugs behind the monitor itself too.. remove the plastic frame around the screen clipped in at the top and bottom (corners), 2 small cross screws on the top left, and to at the bottom right. Once they're out, simply pull the screen forward, and you should see the 2 cables (blue/white) connectors, try pressing/squeezing the connectors/wires whilst the screen is on... If that doesn't fix it, you'll need a new screen
