Nav + Comms bluetooth voice command "phonebook empty"
4450 4
Hi All,
I own an E39 M5 with retrofitted bluetooth and voice command (don't have the manual for these).
I can use the voice control to dial a number fine, but if I try and dial a voice I just get told "phonebook empty" even thought the phone has successfully transferred it's contents to the bluetooth unit.
What am I doing wrong? Do I have to manually tag names I want somehow, or maybe this just isn't supported with my combination of hardware?
1 - 5 of 5 Posts
you need to store names and numbers for the voice dialling in the car itself; press and hold the button on the MFSW, say "Store Name" after the prompt, then you will be guided through the process.
- please speak the name -> please repeat -> please speak the number. When you finalized the number, say "Save".
And repeat process for each additional number.
If you do drive into different area codes then it is a good idea to store the full phone number with area code.
thanks for that info.. btw does anyone have the complete list of voice commands? My E39 did not come with the manual which lists the commands
oh I did search but nothing came up (other than the commands that the lady gives in the help prompt) :)
thanks for the help
pdf file in new thread here.
1 - 5 of 5 Posts
