1 - 6 of 6 Posts
This took some effort cherrsagai
So tell me what you guys think, Good, bad, ok?
and if you can, what I may need to get done.
Before Warranties run out..
There are couple of Service codes that wasn't
listed in the PDF file I downloaded:
THey are :
85990091MP
85990092MP was done twice
85990093Mp
85990088MP
Have no clue what the 4service codes are. anyways..
Ill list the date/mileage/ service. from oldest to latest.:
Won't put remedial stuff like a stuck hazard button and
other stuff like cupholders that were fixed on 4 occassions.
all for 05/00 BUILD DATE
8/1/02, 27214K, Airbag
7/30/03, 34951, complete clutch, aircondition compressor
8/6/03, 36588, Fuel Tank Vent valve
1/23/04, 45489, Vanos Noise on start up, Instrument cluster
2/27/04, 45491, front/rear breaks
5/17/05 66434, MAF failure.. Not sure if they fixed 1 or two
7/13/05 71391, O2 Sensor
the above are all the relevant mechanical stuff done.
No where on here does it mention anything of a INSPECTION I.
or oil changes, ,brake fluid, coolant. Is this normal?
So anything you guys know of I should of gotten or
should be getting soon. ????
thanks once again.. :M5eyes:
Super Moderator
codes that end in MP are maintanance plan, i.e. oil services and inspections. You can probably figure it out by the milage. First oilservice (other than the 1200 mile service) would be between 12k and 16k milage, with an inspection next, then oilservice athen inspection2.
On my car, the clutch was listed as MP at 18k miles.
Mike
THey are :
85990091MP
85990093Mp
85990088MP
Other than airbag, those repairs look pretty typical for '00 cars. Fuel tank vent valve not often, but minor. If those are your repairs, it looks good to me, and car was apparently maintained at the dealer.
Man you start alot of threads.
E39 MFIVE said:
Yep.. Mr 1700 post count.. :typing:
Yup most of mine are replies to questions over a more than 2 years. Not 12 started threads on one page 2 weeks after buying the car. On that note Ive gotten a few emails with people saying "he's outta control". Sorry just the messenger.
1 - 6 of 6 Posts
