1 - 14 of 14 Posts
While my car was on the lift I snapped some pics of my springs... I have a clicking noise when I go up inclines... is this the problem or are these H&R spings normal? My installer told me they are installed properly.... please help.
This is the most annoying issue... Gosh darn clicking when left front has load on it. No noise when hitting bumps in straight lines, only when turning. So odd... we will get to the bottom of it Bernie.
Reactions: BD 997
You should not be getting any noise. I've had a couple of noises since I've had suspension work and I've always got rid of it.
You just need to make sure that all the bolts are tight.
Discussion Starter · #9 ·
easier said than done my friend, the installer checked everything under there and then the head foreman at my dealer checked every piece of suspension and tightened every bolt and noise is still there... :(
I think its a Gremlin living under there personally. We will find out within the next two weeks Bernie.
First time it happen I asked the dealer to check and they found nothing wrong.
Took it back to the place that did the install and they found it.
I had a very slight sound that I could only hear with the stereo off at slow speed over small bumbs when turning, that I guess sounds like a click, but I would describe it more like a very slight creak.
This was caused by just one bolt.
At the bottom of the strut, there are 2 bolts on the left front:
One is the pinch bolt that holds the strut in place
The other I think holds the bracket for the headlight control thingy, it was this nut, it was not loose, but it was not quite as tight as the others, after tightening it, my car was perfect.
I should be able to get a pic if you want.
NB:
No need for the pic as I know exactly what part you are talking about. Thank you for your assistance. We will take a look at that when the car comes back up here.
Reactions: BD 997
I don't think mine touch.
1 - 14 of 14 Posts
