Hey guys, so I started her up today after 3 months of sleep, it started first time no problem, a bit lumpy at first but then ran fine. The tapping that I had before on start up was even worse, coming from the rear of the left bank, so I left it running for about an hour earlier, noise has gone completely but I'll hold judgement until another cold start.
There is a slight vibration that was not there before. It is there from idle all the way to about 3k rpm, then it seems to disappear? Any ideas?
I thought I would run a diagnosis with the BMWCarsoft and it kept coming up with the message 'Status: Module does not respond!' for every check! Also tried to view live data, comes up with 'Error! Module does not respond!' I also reset the service interval as I forgot to do it when it got serviced just before it got put to sleep, it came with 'Service interval has been reset!' then if I switch the car off, twist the key back to ignition, it's still on an orange light? Any help would be greatly appreciated, thanks
Lee
Lee
