I had the Beast aligned at the dealership in summer 2009 after the installation of the Dinan Stage I suspension from the group buy. Around that time, I swapped out the front tires to some older but basically brand new Dunlop 8080's. Fast forward to summer 2010 and they were seeing some unusual wear, very heavy on the inside tread of both tires. I put on brand new Sumi HTRZIII's in Fall 2010 and now am observing again very strong wear just on the absolute inside of each tire, whereas the rest looks practically new (fronts usually wear far better than the rears, of course, and the wear rating of that tire is pretty decent).
I'm attaching the scan of my alignment as I suspect I may still have too much Toe in the front? Can the Total Toe being 0 degrees 14' cause this issue? Is total toe the same as cross-toe? I've seen the FAQ and all the good info posted here on OEM alignment specs, DINAN recommendations, etc. I actually gave that printout to the BMW service adviser and discussed the procedure with him. However, I didn't push to have the alignment done with only weight in the driver's seat, which is my usual mode of driving.
Anything else you guys see on this alignment spec sheet as being an issue? If I gotta go in again, I'll do it to save some wear on tires. Just did the rears in new matching Sumi III's also.
thanks!!
SP
thanks!!
SP
