Hi guys,
I am almost out of CPO (November 12th 2014) and I have some weird noises coming from the clutch/drive line, as well as idle fluctuating issue as well as when increasing RPM from idle till 3K (idle or driving) there is pretty significant vibration coming form the engine(almost as I have bad engine mounts)
When car is just idling on a neutral I can hear humming/light grinding noise coming from the transmission, interestingly when I press the clutch, noise disappears
(sounds in reverse what should be happening if I had a bad throwout bearing). Also I can hear a free play in drive line going over the bumps when off the gas and when shifting 2nd to 1st (again off the gas), as well as when I decelerate on the highway I can hear some wining noise (sounds like worn out bearing).
So I took a car to dealer, demonstrate the noise to service man, he admitted hearing it (as well as jumping idle issue 600 -1200 any time I start the car and until I drive for at least 2 miles) and told me that he thinks that tranny noise related to the engine idle issue and vibration at low rpm.
So a couple of days later they tole me to come to pick the car.
The solution to idle issue: they added a can of techron additive to the fuel tank and told me to drive at least 2 tanks of fuel (done that nothing changed)
The solution to transmission noise: it is normal, with mileage and wear of "clutch pack" it will end up making some extra noises and won't be completely silent. (dealer told me that BMW service rep was visiting them at that time and that was his conclusion).
The solution to engine vibration: it is normal, S85 vibrates on low rpm until it reaches it's "normal" rpm.(mounts good and no cracking).
I personally feel it is a total BS! The humming/soft grinding noise coming from tranny is either a bad throwout bearing or tranny input shaft bearing or possibly something related to the clutch. Funny thing is that I also still have extended maintenance plan that would cover new clutch as well.
Can anybody suggest if I can fight them somehow and make them find what the issue is?
Does anybody reading this has MT6 transmission and could confirm that there is no difference in noises when idling with clutch released or pressed, I would appreciate that (I am right now at 94K miles).
Regarding fluctuating idle issue I was reading on the board that it could be related to a bad alternator. One thing I noticed today is when I increase engine RPM my dome light in the car becomes a lot brighter and when car goes back to idle it dims back, is this indication of possible bad regulator ?
