If you own a MKIII and have these symptoms this fix (might ) correct it. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com
ffice
ffice" /><o
></o
<o
></o
Symptoms:
<o
></o
></o
<o
></o
></o
Tools that you will need:<o
></o
<o
></o
> </o
<o
> </o
FIX:
<o
> </o
:cheers:
DREW
<o
Symptoms:
<o
- Blank Screen with white lines top and bottom.<o
></o
- Radio and CD changer works along with buttons to operate but music shuts off after 2-5 minutes. Can be powered on and same thing happens again music shuts off.<o
></o
- CD is stuck in NAV.<o
></o
<o
- You tried to upgrade to v26 with a hack splash screen or other non OEM files.<o
></o
- You tried to upgrade and the cd was corrupted and stopped mid way.<o
></o
- You replaced your battery and this happened.<o
></o
- You changed your radio fuse and this happened.<o
></o
<o
- You need to download v23 at this site. http://www.x5world.com/articles/all-bmw/navigation/9483-bmw-navigation-operating-system.html
- You need to download this burning software ALCOHOL 120%, trial version here http://www.free-downloads.net/programs/Alcohol_120_
- Download Winrar 3.51 so you can decompress files here http://www.rarlab.com/download.htm
<o
FIX:
<o
- Unzip and extract all files to a destination you choose with WINRAR
- Open Alcohol 120% and select burn from image, hit browse and select the folder you extracted to. Then select the file with the extension CCD and hit next. You will notice that 3 files populate with about 250mb. Hit next to continue.
- Burn at 4x speed on a name brand disc, Memorex and better.
- Explore cd to verify that it is readable, do this a few times and make sure it recognizes quickly by your pc and test open and folders or sub folders.
- Go to your Beast and turn the key to the 2<SUP>nd</SUP> dial, make sure your stereo is off, remove key and close door.
- Open trunk, insert CD then CLOSE TRUNK.
- Go into the car and turn key to 2<SUP>nd</SUP> dial, Stereo should still be off.
- Leaving key as is, exit car and close door.
- You can wait but it is best to leave car behind for about 30-45mins and come back.
- If this works your system will read update complete press okay to reboot.
- I am free for lunch.
:cheers:
DREW
